Quick help with adding users from an array to a group
Brendan Hallida
Hi all,
I am pretty sure that I am close, however, the script is not running for all users in the array.
This is what I have so far:
var admins = ["user1","user2"]; //array
for(var i = 0; i < admins.length; i++) //for loop
var gr = new GlideRecord('sys_user_grmember');
gr.initialize();
gr.user = admins[i];
gr.group.setDisplayValue('Admin')
gr.setWorkflow(false);
gs.print(gr.insert());
So the script adds user1 to the group, and then also adds a blank entry in the user list of the group
anyone know what I'm missing?
Thanks, Brendan
Morning Brendan,
Try out the code below, i've just given it a little test and it seems to work as required. Obviously you'll need to change the user names and the group to whatever is on your instance.
var admins = ["abel.tuter","abraham.lincoln"];
for(var i = 0; i < admins.length; i++) {
	//check user is not already in group
	gr.addEncodedQuery('user.user_name=' + admins[i] + '^group.name=Service Desk');
	gs.debug(admins[i] + ": " + gr.hasNext());
	if (!gr.hasNext()){
		//use user_name to get the user record
		var usrGr = new GlideRecord('sys_user');
		if(usrGr.get('user_name', admins[i])) {
			//add the new record to the group
			gr.initialize();
			gr.user = usrGr.getValue('sys_id');
			gr.group.setDisplayValue('Service Desk');
			gs.debug(gr.insert());
		else{
			// User not found by user_name
			gs.error('Cannot find user: ' + admins[i]);
26 REPLIES 26
Morning Brendan,
	if (!gr.hasNext()){
			gr.initialize();
		else{
Brendan Hallida
Thanks so much mate, that did it!
