‎10-22-2017 09:29 AM
I am receiving NaN error when two numbers are getting divided and even Zero divided by number gets me Nan Error. Below are the screenshot of error and the scripts.
I am trying to divide numerator with denominator and arriving at the result.
Here is the code
// SERVICE REQUEST
if(current.backup_type=="Service Request"){
var cal = new GlideAggregate('x_pm_service_request_backup_template');
ret = cal.addQuery('pri',current.priority_one);
ret.addOrCondition('pri',current.priority_two);
cal.addQuery('service_provider_name',current.sp_name);
cal.addQuery('si_sec',"Met");
cal.addQuery('service_month',current.serv_mon);
cal.addAggregate('COUNT');
cal.query();
var numerator = 0;
if(cal.next())
numerator = cal.getAggregate('COUNT');
//SERVICE REQUEST EXCEPTION
var exp = new GlideAggregate('x_pm_service_request_backup_template');
var pri = cal.addQuery('pri',current.priority_one);
pri.addOrCondition('pri',current.priority_two);
var ret= exp.addQuery('exp_status',"Approved");
ret.addCondition('si_sec',"Not Met");
exp.addQuery('service_provider_name',current.sp_name);
exp.addQuery('service_month',current.serv_mon);
exp.addAggregate('COUNT');
exp.query();
var exception = 0;
if(exp.next())
exception = exp.getAggregate('COUNT');
var res1= (parseInt(numerator) + parseInt(exception));
current.si_num = res1.toFixed(0);
var cal1 = new GlideAggregate('x_pm_service_request_backup_template');
//cal1.addQuery('pri',current.priority_one);
var ret = cal1.addQuery('pri',current.priority_one);
cal1.addQuery('service_provider_name',current.sp_name);
var addups = cal1.addQuery('si_sec',"Not Met");
addups.addOrCondition('si_sec',"Met");
cal1.addQuery('service_month',current.serv_mon);
cal1.addAggregate('COUNT');
cal1.query();
var denominator = 0;
if(cal1.next())
denominator = cal1.getAggregate('COUNT');
current.si_deno = denominator;
var res = (res / denominator) * 100;
current.si_vr = res.toFixed(2);
current.update();
Appreciate your quick response
Narmi
‎10-22-2017 10:18 AM
you can use the below code to convert
var a = g_form.getValue("short_description");
var b = g_form.getValue("description");
var c = (+a) /(+b);
alert("hello"+c);
var c = (+a) /(+b);
alert("hello"+c);
‎10-22-2017 08:09 PM
Hi Chandu,
Thank You for your inputs, The same old formula worked for me, I just had to modify the variable (from res to res1) when it was doing the final division.
Its a server side script in UI action. Any suggestion on how I can improvise this script?
Narmi
