Reference qualifier not working on Dictionary Entry Override
abigailtaba
Issue with the Assignment Group Field in the incident_task Table
I want to specify that only groups with a defined group type should be shown in the Assignment group field. However, when I applied the filter, 15 records are displayed. Yet, when I use the same filter in the reference qualifier, only 5 records are shown.
Any idea
That's helpful.  I meant to ask for these results too, but if you could also show a list view of the table containing the columns Name Type and Parent, with the filter that should clarify things
If you change the attribute in the override to tree_picker=false you will see a similar list view, with whatever columns you define in the List Layout - if this view is clearer for you, and you don't need or want to see the group members
20 REPLIES 20
vinay3253618432
Please try below code.
javascript: 'typeLike1cf74ad7fb9d9290140f0ff5eefdc7c';
