ā04-01-2019 01:55 AM
Hello there. This is my first time using Reference Qualifier and Variable Attributes
In the process of creating a Record Producer, I've created two variables to determine Country and Site where I use two different location lists. What I want to accomplish is when Country is chosen, for an example USA, the Site Lookup Select Box will update and only show the sites belonging to that country.
FYI, the lists name below:
Country list: core_country.list
Site list: cmn_location.list
I went to check core_country and get the ID for the ISO Short (core_country.iso3166_2) which is the column for shortcode of the country (US, UK, DK, etc). I went to cmn_location and found the equivalent (cmn_location.country), i.e the shortcode (column Country) for Country. My idea was to find a "shared column" in both lists.
To sum up, core_country.iso3166_2 only have one entry pr. shortcode. Cmn_location.country has any many entries as there're sites at the specified location.
With that, I made the below Reference Qualifier. Which did not work at all
ref_qual_elements = core_country.iso3166_2;
Do any of you have any idea what I could try?
Best regards,
Stefan
Service Portal Development
ā04-01-2019 03:14 AM
Hi there,
Because the dotwalking on the variable won't be possible, you would have to use a Script Include. Not that hard to setup, just tested the below scripting, works instantly.
Though, as I already mentioned, because the Country field on Location is a String, this could be very tricky. Already with testing out of the box, I'm encountering stupid differences. For example, United States of America being USA (matches country ISO Long, Australia being... Australia instead of AUS (doesn't match country ISO Long).
Kind regards,
Mark
ā04-01-2019 04:05 AM
Hi Mark!
Thank you so much, it's working like a charm.
You're a true hero!
I appreciate a whole lot.
Have a wonderful day š
ā04-01-2019 04:29 AM
Hello again, Mark.
I have one final question I really hope you mind answer.
Some of the fields in the Country list doesn't have any Sites connected to it. How can I remove these redundant entries (Countries) in the Country List?
Hello again, Mark.
ā04-01-2019 02:25 AM
Hi Mark.
An advanced reference qualifier is exactly what I am trying - I am not able to come up with a solution in regards to that picture. It is a Record Producer indeed, core_country.iso3166_2 is the Country Shortcode of the core_country list, so yeah, current.variables.core_country.iso3166_2 I assume it would be.
Maybe with below info you'll have a better shot?
Country list info:
- Type: Lookup Select Box
- Lookup from table: Country [core_country]
- Lookup Value field: Name (OBS! This is the full name of the country, not the ISO Short which is the country code)
- No reference qualifier
Site list info:
- Type: Reference
- Reference: Location [cmn_location]
- Use reference qualifier: Advanced
