Requested for keeps showing opened by on order guide
jean-pauldehaas
we discovered that when a catalog item is submitted trough an order guide the approval related list shows the opened by in the requested for field (screenshots), this only happens when submitted trough an order guide.
doing some research i found that this is OOB behavior for the order guide , but i wonder if someone was able to find a solution for this anyway ?
@jean-pauldehaas
I don't see any difference
Remember on RITM list there is Opened by coming from Request.Opened by as well
when RITM is from Order Guide, I could see Opened By and Requested For same user i.e. 2 columns
When stand-alone RITM then also both are same
Dr Atul - LNG
Hi @jean-pauldehaas
I tried at my end via order guide and i can see REQ in approval.
@Dr Atul - LNG  i dont see a requested for field in your approval section, thats where i am seeing it.
You may be referring to the RITM level, but when I check on my end, I can't see that field. It might be something in your configuration.
yeah i had to reset column defaults to show it
