RESTMessage endpoint max string length ?
hpesata
Kilo Expert
Hi!
I created a RESTMessage which enables our Calgary-SN application to talk to he JIRA Rest API, I am using a MID-server.
I am not able to successfully use the "get" function, I always get an error 400.
After digging around, I found out, that the RESTMessage-endpoint URL gets cut off after 120 characters which causes the 400 error.
I found the information about this fact within RESTprobe entries in the ECC Queue.
The source field of the "ecc_queue" table was indeed set to 120, I raised it up to 1024 and restarted the MID-server,
but still the endpoint url gets cut of after 120 characters...
Where can I find the real 120 character limit and raise it up ?
Thanx in advance!
regards,
Hans
12 REPLIES 12
Hi Durga!
As I have described, You dont only have to increase the max_length property of the ecc_queue table but also of ALL rotated tables ecc_queue0000, ...
This worked for me.
regards,
Hans
poyntzj
raise a request in HI and they will make it larger for you
I had this recently
Hi Julian,
Thanks for the update.
It will really help me fix my issue.
Durga
Jacob_Andersen
I had this same problem several months ago and banged my head against the wall until I realized it was a rotated table.   I wish that I would have seen this forum post in time to point you in the right direction .   I knew exactly what it was when I read your post.
I was told that this bug was fixed in Dubin.
nari5
Kilo Explorer
I just had this issue today (again) .. what I did and it worked for me (again) was go to table rotation and synchronize shard .. wait for a while and retry.
I guess it's a good first try before raising a ticket on HI
