Run flow based on system property
Andr_ Pires
I have a system property where the user writes a specific number of days.
I want to get that property and use the flow designer to run a flow every those "x" days.
The problem with flow designer is that there isn't any way to use a script in the trigger option and I honestly don't see another way.
Appreciate if you guys could help.
Ankur Bawiskar
@Andr_ Pires
for such requirement I would suggest to use scheduled job rather than flow
Flow are designed for low-code, no-code
Ankur Bawiskar
@Andr_ Pires
Okay, will do scheduled job then. I was just asking here in case there was any way with flow designer.
best regards,
André
