Running a script include in a sysID filter
ServNowDev
I am trying to return all approvals for a specific Catalog Item, i have the script working but i want to run when you select on a module in the navigation.
Here is my script:
var approvalTest = Class.create();
approvalTest.prototype = Object.extendsObject(AbstractAjaxProcessor, {
populateApprovals: function() {
        var approvals = [];
        var grApprovals = new GlideRecord('sysapproval_approver');
        grApprovals.addQuery('state', 'requested');
        grApprovals.query();
        while (grApprovals.next()) {
            var grRitm = new GlideRecord('sc_req_item');
            grRitm.addQuery('active', true);
            grRitm.addQuery('sys_id', grApprovals.sysapproval);
            grRitm.query();
            if (grRitm.next()) {
                approvals.push(grApprovals.getUniqueValue());
        return approvals.join(',');
    type: 'approvalTest'
here is the filter but it returns null , is there a way to run javascript via a filter,
here is the module setup:
lauri457
Check the sys_property glide.script.use.sandbox on your instance, you need to make the SI either client callable or sandbox enabled for the script to work in a list filter.
Also you are doing nested queries in your script, for every row of approvals your script does a query for a matching ritm. Here are two alternative ways to achieve your result in a more performant way. Either adding a join sub query or by adding dot walked conditions.
var approvalSysids = []
var itemApprovalGr = new GlideRecord("sysapproval_approver");
itemApprovalGr.addQuery("state", "requested");
itemApprovalGr.addJoinQuery("sc_req_item", "sysapproval", "sys_id")
	.addCondition("active", true)
	//.addCondition("cat_item", [item sysid]);
itemApprovalGr.query()
while (itemApprovalGr.next()) {
	approvalSysids.push(itemApprovalGr.getUniqueValue())
	.addCondition("sysapproval.sys_class_name", "sc_req_item")
	.addCondition("sysapproval.active", true)
	//.addCondition(""sysapproval.ref_sc_req_item.cat_item"", [item sysid]);
 Note the significantly lower sql count and response time that can be achieved using above logic instead.
looks good, seems you need to debug the script logic. and review lauri457 response, make sure you're returning a comma separated list of sys_ids.
lauri457
Ankur Bawiskar
@ServNowDev
there are lot of OOTB left nav modules which call script include.
check those and modify yours one as per that
💡 If my response helped, please mark it as correct and close the thread 🔒— this helps future readers find the solution faster! 🙏
