Script Include for reference qualifier
Nataliia_Lova
Hi there,
I need restrict options on Location Dropdown to patient addresses. Required conditions are:
  • Where “Type” = Health Location or Health Depot, OR
  • Where the linked Consumer on the location is the same as the Consumer on the Patient associated with a WOT
I wrote the Reference Qualifier in Dictionary Entry Override:
cmn_location_type=health_location^ORcmn_location_type=health_depot^ORconsumer="+current.work_order.x_table_patient_name.consumer
However, only the first condition works (Type = Health Location or Health Depot).
The condition with consumer="+current.work_order.x_table_patient_name.consumer does not seem to be working.
My manager suggested me to use this Script Include methods for the reason:
getLocationAndTerritoryHospitalIDsForConsumerFromGr: function(gr) {
        var consumer_sysid = '';
        var table = gr.getTableName();
        if (table == 'sn_hcls_appointment') {
            consumer_sysid = gr.patient.consumer;
        if (table == 'wm_task') {
            consumer_sysid = gr.work_order.u_appointment.patient.consumer;
        return this.getLocationIDsForConsumer(consumer_sysid).join('^NQ');
    getLocationIDsForConsumerFromGr: function(gr) {
        return this.getLocationIDsForConsumer(consumer_sysid)[0];
    getLocationIDsForConsumer: function(consumer_sysid) {
        /* returns location sysids in array */
        var consumerSysID = '';
        if (consumer_sysid) {
            consumerSysID = consumer_sysid;
            consumerSysID = this.getParameter('sysparm_consumer_sysid');
        } // end if else make client callable as well
        var locationIDs = [];
        var territoryIDs = [];
        var state = '';
        var tableName = 'cmn_location';
        var encQry = 'consumer.sys_id=' + consumerSysID;
        var gr = new GlideRecord(tableName);
        gr.addEncodedQuery(encQry);
        var getRowCount = gr.getRowCount();
        while (gr.next()) {
            var locationSysID = gr.sys_id.toString();
            var locationName = gr.name;
            locationIDs.push(locationSysID);
            if (gr.u_territory) territoryIDs.push(gr.u_territory.toString());
            state = gr.state.toString();
            gs.info('locationName ' + locationName + '\n' + 'locationSysID ' + locationSysID);
        var locationSYSIDs = 'sys_idIN' + locationIDs.toString();
        var territoryHospitalSYSIDs = 'cmn_location_typeINhealth_depot,health_location^ORDERBYconsumer';
        /*if (territoryIDs.length > 0) { // add a territory filter
            territoryHospitalSYSIDs += '^u_territoryIN' + territoryIDs.toString();
        } else { //else filter by state
            if (state) territoryHospitalSYSIDs += '^state=' + state;
        return [locationSYSIDs, territoryHospitalSYSIDs];
    getstringback: function(given) {
        var answer = given;
        return answer;
My questions are:
  1. Should this Script Include be client-callable, server-callable?
  2. Since the Script Include returns an array, and a Reference Qualifier must be a string, how can I use these methods in a Reference Qualifier?
Thanks in advance!
Bert_c1
If you get what you want in Scripts Background, then use the something like:
javascript:'sys_idIN'+new sn_customerservice.CaseTaskHelper().getCaseTaskAccounts(current);
in the 'Reference qual' field. This is from an existing OOB dictionary record for Account on the sn_customerservice_task record. (replace ':' with ':' in the above.
