Script include function not working when called from client side
Khalnayak
Hi all,
I have a record producer on which I want to show the assignment group the HR case will be assigned to.
SO I have a script include within which I am calling a function and then using a onchange client side script to call the script include and display the group in the item.
This is the code for the getAG function in the script include.
getAG: function(){
		//var current = this.getParameter('sysparm_current');
		gs.debug('HR AG');
		var subjectPerson = this.getParameter('sysparm_req_for');
		var prodID = this.getParameter('sysparm_prodID');
		var contactType = 'Self Service';
		//var source = '[producer.source]';
		var AG = '';
		var grHrService = new GlideRecord('sn_hr_core_service');
		grHrService.get('producer', prodId);
		var currentServiceTable  = grHrService.getValue('service_table');
		var currentTopicCategory = grHrService.topic_detail.topic_category.getDisplayValue();
		var currentTopicDetail   = grHrService.topic_detail.getDisplayValue();
		var currentHRServiceName = grHrService.getDisplayValue('name');
				var grSubjectPerson = new GlideRecord('sys_user');
				grSubjectPerson.get(subjectPerson);
				var currentLocation = grSubjectPerson.getValue('location');
				var grCase = new GlideRecord(currentServiceTable);
				grCase.setValue('hr_service',     HrService);
				grCase.setValue('contact_type',   contactType);
				grCase.setValue('source',         source);
				grCase.setValue('subject_person', subjectPerson);
				grCase.setValue('location',       currentLocation);
				var grAssignmentRule = new GlideRecord('sysrule_assignment');
				grAssignmentRule.addActiveQuery();
				grAssignmentRule.addQuery('table', '=', currentServiceTable);
				grAssignmentRule.orderBy('order');
				grAssignmentRule.query();
				var filter;
				var found = false;
				while ( grAssignmentRule.next() && found == false ) {
					filter = grAssignmentRule.getValue('condition');
					if ( filter == '' ) {
						continue;
					found = GlideFilter.checkRecord(grCase, filter, true);
					if ( found ) {
						gs.info('HR AG match: ' + grAssignmentRule.getDisplayValue('group'));
						gs.log('HR AG match: ' + group);
						AG = grAssignmentRule.group;
						return AG;
				if ( found == false) {
					gs.info('HR AG: no match');
and then this is the client script that is calling the script include function:
	var ga = new GlideAjax('sn_hr_core.HRCaseAccessRP');
	ga.addParam('sysparm_name', 'getAG');
	ga.addParam('sysparm_req_for', producer.requested_for);
	ga.addParam('sysparm_prodID', g_form.getUniqueValue());
	ga.getXMLAnswer(getResponse);
	function getResponse(response){
		var answer = JSON.parse(response);
		g_form.addInfoMessage(answer.AG);
		g_form.setValue('assignment_group', answer.AG);
so the onchange client script works in the sense it displays the showfield message banner so the blue bit under the field. But there is no data or group shown in the field message. it is blank.
I have added some gs.logs within the script include function I am calling but they are not displaying in the logs at all.
So looks like script include is not being called.
The script include is in the HR core app scope and the client script is in the employee center core scope.
The script include caller access is set to none so that should not restrict and accessible from is all app scopes.
Can someone help me on this please.
Kailash Bhange
Hi Khalnayak,
I suppose your code is failing at below highlighted lines as the variable defined is different one here, please make corrections.
Hope this helps.
If my answer resolves your issue, please mark my answer as ✅ Correct & Helpful based on the validations.
Thank You!
Kailash
17 REPLIES 17
Hi
see the following video for the try-catch-block: https://www.youtube.com/watch?v=-PAI9jmUWMM
For debugging best practices see https://developer.servicenow.com/dev.do#!/guides/rome/now-platform/tpb-guide/debugging_best_practice...
Kind regards
Maik
Thanks @Maik Skoddow but I think the script include is not even running hence why not seeing any errors or so.
None of the gs.log or gs.info are being logged at all.
I only see one log that is related to my script include and that is this:
ccan you advise if this could be the cause and how I could fix it
Harshal Gawali
Giga Guru
Make sure that client callable checkbox should be checked in your script include.
Harshal.
@Harshal Gawali it is checked
Adrian Ubeda
Hi Khalnayak,
In you script include is 'client callable' flag checked? Also should access from all application scopes.
Apart from that, review is there is any restricted caller access record between apps for this SI in sys_restricted_caller_acces table, if status is invalidad change that record to allowed.
If it was helpful, please give positive feedback.
If it was helpful, please give positive feedback! ✔
☆ Community Rising Star 22, 23 & 24 ☆
