script include to set relevant default values based on field and conditions?
Zod
Giga Guru
Hi Experts,
I'd like to create a script include to return the relevant default value for each field calling the script include and based on conditions of the current record ...
Example (just to understand the logic - this is not what is to be achieved ;-)):
IF incident contact_type is phone I wand to return Sys_ID of Group A as a default for assinment group, in case of email it might be Group B.
So I'd like to add in the default_value for assignment group something like javascript: thisFunktion().getDefault(assingement_group);
The script include then should look somehow like this ... to be used
getDefault: function(fieldname) {
if (fieldname == 'assignemt_groupl') {
   var type = current.contact_type
   var isEmail = type == 'email';
   var isPhone = type == 'phone';
      if (isEMail) { return 'Group A Sys ID'; }
      else if (isPhone) { return 'Group B Sys ID'; }
else if (fieldname == 'what_ever_fieldl') {
I have tried this somewhile ago, but somehow it did not work so I'd like to ask for some advise before I start loosing again time doing something stupid.
Sure I could also to a client script calling a script include somehow, but as this is only relevant while initially loading the new record, this does not to be so clever I assume. Anyhow would prefer going this way ...
Any hints on this?
9 REPLIES 9
you are getting value but in object format use JSON.stringify(yourreturen_value);
have you used only this one
defVal = gs.getProperty('u_xxx_default1');
return defVal;
yes only this ....
With JSON I'm not familiar at all ...
function getSPMDefaultValue(current,fieldname) {
gs.info("DEBUG -ServicePortfolioUtil - getDefaultValue - Start");
if (fieldname == 'u_service_availability') {
return "TEST";
... delivers same "object" ...
Abhinay Erra
Here you go
Script include
code:
function getDefaultAssignment(contact_type){
if(contact_type=='phone')
return 'sys_id of group';
else if (contact_tye=='email')
and put this in the default value
javascript: getDefaultAssignment(current.getValue("contact_type"));
