01-16-2023 12:44 AM
Im trying to set the field Operational Impact as mandatory using Script include and on load client script.
I set an Alert in order to see what Im getting from the script include and lm getting 'false' even tho the conditions are met and I suppose to get true.
What am I doing wrong?
01-16-2023 05:19 AM - edited 01-16-2023 05:52 AM
This might be easier with a display business rule which does a GlideAggregate look-up and sets a property in the g_scratchpad object.
The script for your display BR would look something like this:
var department = current.caller_id.department;
var createdOnDate = current.getValue('sys_created_on').split(' ')[0]; // Gets only the Date as string
var agg = new GlideAggregate('u_operational_activity');
agg.addQuery('u_departments', department);
agg.addQuery('u_from_date', '<=', createdOnDate );
agg.addQuery('u_to_date', '>=', createdOnDate );
agg.setLimit(1);
agg.query();
if (agg.hasNext()) {
g_scratchpad.operationalActivity = true;
g_scratchpad.operationalActivity = false;
})(current, previous);
And then your client script can be really simple, no need for Script Include or GlideAjax:
function onLoad() {
if(g_scratchpad.operationalActivity) {
g_form.setMandatory('u_operational_impact', true);
g_form.setMandatory('u_operational_impact', false);
Please review the code as I didn't have the time to test it, especially that I don't have your exact same custom table either.
01-16-2023 05:36 AM
@laszloballa Thank you so much!! can you please just explain me how the comparison to u_operational_activity table fields is made without mentioning the name of the table?
01-16-2023 05:50 AM
Apologies, there is an error in the code. The GlideAggregate should actually be on the 'u_operational_activity' table and not on incident. That's how 😄 I will correct my previous post.
01-16-2023 01:09 AM
Hi @Alon Grod ,
Let us debug this like this:
Go to background scripts
paste the code whatever you've written in script include into background script:
var inc = new GlideRecord("incident");
inc.addQuery("active",true);
inc.query();
while(inc.next()){
var gdt = new GlideDateTime(inc.sys_created_on);
gs.log(gdt +" : created on time");
gdt = gdt.getDate();
gs.log(gdt + " : created on date);
//Write your extra code here
instead of return oper.hasnext(); write as below
var recordPresent = oper.hasnext();
gs.log(recordPresent);
Let us know what are the logs printed after running the background script, from there we can analyse more.
01-16-2023 02:30 AM
@Basheer hi i think the problem is that Im not getting the department correctly using inc.caller_id.department.
how can i get the department of the caller of the incident?
01-16-2023 02:37 AM
Department is a reference field. It will provide the sys_id of the department.
Is u_operational_activtiy has u_departments as reference field???
If u_departments is not reference field then you need to get caller_id.department.name
