Set field mandatory using Script Include and Client script
Alon Grod
Im trying to set the field Operational Impact as mandatory using Script include and on load client script.
I set an Alert in order to see what Im getting from the script include and lm getting 'false' even tho the conditions are met and I suppose to get true.
What am I doing wrong?
This might be easier with a display business rule which does a GlideAggregate look-up and sets a property in the g_scratchpad object.
The script for your display BR would look something like this:
    var department = current.caller_id.department;
    var createdOnDate = current.getValue('sys_created_on').split(' ')[0]; // Gets only the Date as string
    var agg = new GlideAggregate('u_operational_activity');
    agg.addQuery('u_departments', department);
    agg.addQuery('u_from_date', '<=', createdOnDate );
    agg.addQuery('u_to_date', '>=', createdOnDate );
    agg.setLimit(1);
    agg.query();
    if (agg.hasNext()) {
        g_scratchpad.operationalActivity = true;
        g_scratchpad.operationalActivity = false;
})(current, previous);
And then your client script can be really simple, no need for Script Include or GlideAjax:
function onLoad() {
    if(g_scratchpad.operationalActivity) {
		g_form.setMandatory('u_operational_impact', true);
		g_form.setMandatory('u_operational_impact', false);
Please review the code as I didn't have the time to test it, especially that I don't have your exact same custom table either.
14 REPLIES 14
@Basheer both are referenced fields (in incident and in oprerational activity tables)
@Basheer what should I do if both referenced fields
Try these scripts in background and let me know if any sys_id is matched
First Script : It will print you the sys_ids of department
var inc = new GlideRecord("incident");
inc.query();
while(inc.next()){
gs.print(inc.caller_id.department +" Department of incident");
Second script
var oper = new GlideRecord("u_operational_activity");
oper.query();
while(oper.next()){
gs.print(oper.u_departments + " Department in operational activity);
@Basheer Im not getting anything from inc.caller_id.department
var OperUtil = Class.create();
OperUtil.prototype = Object.extendsObject(AbstractAjaxProcessor, {
isService: function() {
inc.addQuery('active=true');
inc.query();
while (inc.next()) {
var gdt = new GlideDateTime(inc.sys_created_on);
var date = gdt.getDate();
gs.log('alon' + date);
gs.log('inc dept:'+inc.caller_id.department);
var oper = new GlideRecord('u_operational_activity');
oper.addEncodedQuery('u_departments=' + inc.caller_id.department + '^u_from_date<=' + date + '^u_to_date>=' + date);
oper.query();
return oper.hasNext();
type: 'OperUtil'
@jaheerhattiwale
