setLabelOf() does not work on an RITM
AkshayBhask
I've been working on some form changes, and I've realised that while you can manipulate the label of a field within a catalog form using the setLabelOf(), the same onLoad script would not work on the RITM, and this is my experience currently.
Could you please validate if I'm missing something here - I have a field in a catalog form called 'directorships'. The label of the field is 'Mention the Directorships', and I'm using an onLoad client script to change the label of this field to 'Hello. This is the directorships label.' Whilst the latter label is displayed as expected on the portal, the submitted RITM still shows the old label.
@Ankur Bawiskar
AkshayBhask
For someone looking at this post in the future -
Summary -
We encountered an issue where long checkbox and multiple-choice labels (exceeding 255 characters) could not be stored in the variable Question attribute. To work around this, we tried updating labels dynamically using g_form.setLabelOf() in an onLoad client script. While this correctly updated the label on the catalog form, it did not reflect in the RITM, causing confusion during review. After investigation and confirmation from ServiceNow ( @Epapra Polugari), here are the key takeaways:
Root Cause:
  • g_form.setLabelOf() only changes the label on the client-side catalog UI.
  • It does not update the backend variable question, so RITMs, SCTASKs, notifications, approvals, exports, etc., continue to show the original (trimmed) label.
  • This is a platform limitation and expected behaviour.
Recommended Approaches:
  • Use a Rich Text Label variable
    • Add a Rich Text Label (or similar descriptive variable) above/below the checkbox.
    • No character limit; displays correctly in both catalog forms and RITMs.
  • Use Help Text or UI Policy Messages
    • Keep the variable label short.
    • Place the long compliance explanation in:
      • Help text
      • A Catalog UI Policy field message
      • A Rich Text/HTML container variable
  • Avoid using setLabelOf() for data that must be stored or audited.
    It only affects the browser view and does not propagate to backend records.
Regarding Extending the Question Attribute Length
  • Increasing the max length of the Question field is not recommended.
  • The variable label is used across the platform (RITMs, tasks, approvals, exports, PDFs, emails).
    Longer text can:
    • Impact performance (label rendering happens frequently)
    • Reduce readability across downstream processes
AkshayBhask
Summary -
Root Cause:
      • Help text
    Longer text can:
@AkshayBhask
the answer/solution you shared doesn't relate to the question you asked.
It's a workaround
I believe I shared a working link which will help you in your original question.
As per new community feature you can mark multiple responses as correct.
💡 If my response helped, please mark it as correct ✅ as well so that this helps future readers find the solution faster! 🙏
Hi @Ankur Bawiskar ,
Thanks for sharing your thoughts on my earlier response. I really appreciate you taking the time to contribute. From my side, I felt that the summarized comment aligned more closely with the core question, since the primary point was confirming the system limitation. The workarounds were added only after further discussions with @EpapraP , as complementary guidance rather than the main solution.
I also wanted to mention that the link you shared in your first comment, while helpful for UI adjustments, doesn't fully address the broader challenges in this scenario,, such as column names for reporting, filter conditions or any downstream use where backend consistency matters.
That said, I value your input and the spirit of collaboration on the community and I've marked your responses as helpful. Looking forward to future discussions with you!
Akshay
