Sub-Flow Output Error in Flow?
Matthew Gill
I am calling Sub-Flows within a Flow. The Sub-Flows return [status] which is a True/False variable. The Sub-Flow tests correctly, but when it is called from the Flow the Sub-Flow completes, returns the appropriate output when looking at the subflow execution details, but the Flow execution details show an error for the Sub-Flow task.
It is as if the Sub-Flow output variable is not being passed back to the Flow. I have ensured that the variable types are the same, and the Sub-Flow is set to 'Wait for Completion). Any advice or guidance is appreciated. Thank you!
Matthew Gill
Alright... Support figured out what the issue was.
Even though the error was being shown on the Sub-Flow call, the issue was actually failing on the Update Record Action. Specifically, updating the 'Actual Start' field. I was updating to " return ( new Date() ); "; however, that field requires a String, for some reason, and was not giving a good Error Code. The workaround is to update to " return ( new Date().toString() ); ". Not ideal, but it works...
Thanks everyone for helping!
20 REPLIES 20
I would try to end your subflow with an
if (condition)
--> assign subflow output (true)
else
--> assign subflow output (false)
Just to make sure that the variable is Always set.
Generally I avoid setting the output within an if statement, because you risk ending the subflow without setting a required/expected value.
Good idea:
Unfortunately, exact same error. Not having an opposing 'Else' has bitten me before in another unrelated Flow.
Just a hunch and maybe worth a try to rule something out regarding the true/false type.
Can you maybe flip the sub flow output type to a string. And just try passing back a string value. At least to see if it processes without error.
Geoff
Good call Geoff, that would have been my next advice.
Create an additional output, a string, and assign it a value at the end of the subflow, just to make sure that something is returned at all.
I added an additional output variable as a string, and set the value to "0" or "1" depending on the outcome. It still failed; however, I noticed something. The Error ocurrs just a few seconds after the Sub-Flow is called from the Flow. The Sub-Flow is still running when the Error is thrown in the Flow. In fact, the Sub-Flow runs for an additional 3 minutes or so to finish it's tasks and sets the output variable. But by that time the Flow is already dead, so it can't receive the output variables.
