UI Macro/g:evaluate help
matthew_magee1
Giga Guru
Hi all,
I'm trying something new (for me). I've got a UI Macro that I'm modifying.
I've added the following g:evaluate tag:
<g:evalute var="cart_count" object="true">
var cart_count = new GlideAggregate('sc_cart_item');
cart_count.addAggregate('SUM','quantity');
cart_count.addQuery('active','true');
cart_count.addQuery('sys_created_by',gs.getUserName());
cart_count.setGroup(false);
cart_count.query();
cart_count;
</g:evaluate>
The above code will give me a quantity for the number of catalog items I have in a shopping cart for the current user. This works great.
Later in the code, I have this <j:if> statement:
<j:if test="${cart_count.next()}">${cart_count.getAggregate('SUM','quantity')}</j:if>
The above code works great if all I want to show is how many items a user has in his/her cart.
What I'd like to do is throw an if statement that checks if the cart quantity for a user is 0:
if (SUM == 0/null) {
display '0'
else {
Obviously I have the 2nd half working, just not sure how to do the 1st half. Any help is greatly appreciated-
Matthew
This worked for me:
  <g:evaluate jelly="true">
  cart_count.query();
  </g:evaluate>
  <j:choose>
  <j:when test="${cart_count.getAggregate('SUM','quantity')} != 0">
  Number of items:         ${cart_count.getAggregate('SUM','quantity')}
  </j:when>
  <j:otherwise>
  Number of items:         0
  </j:otherwise>
  </j:choose>
  </j:if>
</j:jelly>
3 sc_cart_items:
After deleting the items:
13 REPLIES 13
Mike Allen
You have to use j:choose and j:when...
<j:choose>
        <j:when test="${cart_count.getAggregate('SUM','quantity')} == 0 || ${cart_count.getAggregate('SUM','quantity')} == null}">
                  0
        </j:when>
        <j:otherwise>
        </j:otherwise>
</j:choose>
There is no if/else in jelly.
Mike
Thanks for the reply. I figured I'd have to use a combination of choose/when tags.
Here is my code; when I run the page w/ the macro, I get zippy/nada/nuttin':
  1. <g:evaluate var="cart_count" object="true">
  2. var cart_count = new GlideAggregate('sc_cart_item');
  3. cart_count.addAggregate('SUM','quantity');
  4. cart_count.addQuery('active','true');
  5. cart_count.addQuery('sys_created_by',gs.getUserName());
  6. cart_count.setGroup(false);
  7. cart_count.query();
  8. cart_count;
  9. </g:evaluate>
  1. <j:choose>
  2. <j:when test="${cart_count.getAggregate('SUM','quantity')} == 0 || ${cart_count.getAggregate('SUM','quantity')} == null}">
  3.           Number of items:       0
  4. </j:when>
  5. <j:otherwise>
  6.         Number of items:         ${cart_count.getAggregate('SUM','quantity')}
  7. </j:otherwise>
  8. </j:choose>
Here is a screenshot:
Try this:
        cart_count.query();
</g:evaluate>
        <j:choose>
                  <j:when test="${cart_count.getAggregate('SUM','quantity')} == 0">
                            Number of items:       0
                  </j:when>
                  <j:otherwise>
                  </j:otherwise>
        </j:choose>
</j:if>
I am not a jelly expert but I think,  g:evaluate must have object=true
This worked for me:
  cart_count.query();
  </g:evaluate>
  <j:choose>
  </j:when>
  <j:otherwise>
  Number of items:         0
  </j:otherwise>
  </j:choose>
  </j:if>
</j:jelly>
3 sc_cart_items:
