UI Macro/g:evaluate help
matthew_magee1
Giga Guru
Hi all,
I'm trying something new (for me). I've got a UI Macro that I'm modifying.
I've added the following g:evaluate tag:
<g:evalute var="cart_count" object="true">
var cart_count = new GlideAggregate('sc_cart_item');
cart_count.addAggregate('SUM','quantity');
cart_count.addQuery('active','true');
cart_count.addQuery('sys_created_by',gs.getUserName());
cart_count.setGroup(false);
cart_count.query();
cart_count;
</g:evaluate>
The above code will give me a quantity for the number of catalog items I have in a shopping cart for the current user. This works great.
Later in the code, I have this <j:if> statement:
<j:if test="${cart_count.next()}">${cart_count.getAggregate('SUM','quantity')}</j:if>
The above code works great if all I want to show is how many items a user has in his/her cart.
What I'd like to do is throw an if statement that checks if the cart quantity for a user is 0:
if (SUM == 0/null) {
display '0'
else {
Obviously I have the 2nd half working, just not sure how to do the 1st half. Any help is greatly appreciated-
Matthew
This worked for me:
  <g:evaluate jelly="true">
  cart_count.query();
  </g:evaluate>
  <j:choose>
  <j:when test="${cart_count.getAggregate('SUM','quantity')} != 0">
  Number of items:         ${cart_count.getAggregate('SUM','quantity')}
  </j:when>
  <j:otherwise>
  Number of items:         0
  </j:otherwise>
  </j:choose>
  </j:if>
</j:jelly>
3 sc_cart_items:
After deleting the items:
13 REPLIES 13
Mike-
Thanks for the code. I had to tweek it a little bit to work in the UI Macro 'cms_header_login':
cart_count.query();
</g:evaluate>
<span style="border-radius: 10px;width:20px;height:20px; padding-left:5px;padding-right:2px;padding-top:1px;padding-bottom:1px;font-size:12px:color:white;line-height:20px;text-align: center;background:orange;font-weight:bold;font-family:Arial">
<j2:if   test="${cart_count.next()}">
  <j:choose>
  <j:when test="${cart_count.getAggregate('SUM','quantity').length == 0}">
                            0
  </j:when>
  <j:otherwise>
          </j:otherwise>
  </j:choose>
  </j2:if>
</span>
Here is what the final product looks like:
Again, appreciate everyone's helps-
Matthew
You may run into a caching issue, because all this is in phase 1, which caches.   If you do, switch the code into phase 2 by adding 2 to your g and j tags here and changing the {} brackets to [] brackets in your variables.
I have gotten it to work plenty of times without it, just doing a normal GlideRecord in the evaluate and using the variable that I declared there.
But, then again, just because I got it to work, doesn't make it best practice.
I am not sure either. The phases and the tags are quite confusing actually 😄
