Unable to fetch and set reference value using jelly
Streamline Cam
Hi! I am trying to take a field value from the form and use this to populate a field on a UI page with that value.
But it is not setting/getting the value. If i make my tags $[] I get a black reference value but if I use ${} I get no reference at all, I want to take the value from the record that is already populated.
<g2:evaluate var="jvar_cmdb_id" jelly="true">
        var val = current.getValue('cmdb_ci');
        val;
</g2:evaluate>
<g:ui_reference label="configuration_item" name="configuration_item" table="cmdb_ci" field="name" value="$[jvar_cmdb_id]" displayvalue="Testing" />
@Streamline Cam
since you are in scoped app try this
<g:evaluate var="jvar_ci_sys_id" expression="RP.getWindowProperties().sysparm_ci_sys_id" />
                    <g:evaluate var="jvar_ci_display" expression="RP.getWindowProperties().sysparm_ci_display" />
Thanks for trying Ankur!
Sadly I am not sure what is working, I tried both of your solutions with no luck - does anything look wrong?
UI Action: Quick Close:
function quickClose() {
	var title = getMessage("Quick Close");
	var sysId = g_form.getUniqueValue();
	var dialogClass = GlideModal ? GlideModal : GlideDialogWindow;
	var dd = new dialogClass("sn_si_quick_close_si");
	dd.setTitle(title);
	dd.setPreference('sysparm_ci_sys_id', g_form.getValue('cmdb_ci').toString());
	dd.setPreference('sysparm_ci_display', "Testing");
	dd.setPreference('sysparm_sys_id', sysId);
	dd.setPreference('sysparm_action', "incident");
	dd.setWidth(500);
	dd.render();
And ui page:
<div class="row form-section">
                <div class="col-sm-4 section-title-top"><span mandatory="true" class="required-marker"></span>${gs.getMessage('Configuration Item : ')}</div>
                <div class="col-sm-6">
                    <g:evaluate var="jvar_ci_sys_id" expression="RP.getWindowProperties().get('sysparm_ci_sys_id')" />
                    <g:evaluate var="jvar_ci_display" expression="RP.getWindowProperties().get('sysparm_ci_display')" />
                    <input type="hidden" id="changerequest1" name="changerequest1" value="${jvar_ci_sys_id}"></input>
                    <div id='mydiv3'>
                        <label id='label3' value="${jvar_ci_sys_id}"></label>
                        <g:ui_reference name="changerequest" id="changerequest" table="change_request" value="${jvar_ci_sys_id}" displayValue="${jvar_ci_display}" style="width:180px" />
                    </div>
                    <g:ui_reference label="Configuration Item" name="configuration_item" table="cmdb_ci" field="name" value="${jvar_ci_sys_id}" displayvalue="${jvar_ci_display}" />
                </div>
            </div>
Result:
@Streamline Cam
try this and send the CI display value
        var ciName = g_form.getDisplayBox('cmdb_ci').value;
	dd.setTitle(title);
	dd.setPreference('sysparm_ci_display', ciName);
	dd.setWidth(500);
	dd.render();
UI Page: No change
@Streamline Cam
Hope you are doing good.
Hi Ankur! Thanks for your continued help - unfortunately it still doesn't work, I have debugged a little and this is what I see in the logs:
com.glide.script.RhinoEcmaError: Cannot find function get in object [object Object].
ftp://gsft_database_form/sys_ui_page.ec34dd401b019d906a3c8551f54bcb0c.html ➚.69 : Line(1) column(0)
==> 1: RP.getWindowProperties().get('sysparm_ci_display')
Think this could be scope issue from security incident response?
@Streamline Cam
