URGENT PLEASE!! Flow Designer - If Condition issues
Adil N
Hi Please see all my screenshots below.
to summarise what im trying to do is create a workflow that will automatically assign an SCTask created on the back of a RITM to an assignment group based on the location field selected by the requestor. So for example If location is England, France or Germany then assignment group will be Europe, if the location is Mexico, Canada, Brazil it will be assignment Group Americas
the flow for some reason below does not work can you help me identify the issues please
@Adil N If you do have a large number of locations, that is even more of a reason to use Decision Tables. The UI for creating a decision table is very easy to pick up, and it is quicker to add your logic to the table than it is to build out a long or complex set of if statements.
Regardless of whether you if statements or Decision Table, be sure to get a good understanding of the data structure and hierarchy in the Location table (assuming that your variable is a choice reference that pulls locations from that table). There are logical geographic groupings here that you can leverage, and instead of calling out the individual locations, it would be easier to dot-walk to a common field (such as region).
Even in times of rushed development, you should always set a strong foundation for future extensibility. You never know how long your solution will be in place, nor the next time that you will have a chance to update it.
15 REPLIES 15
@Adil N This is another option if you do not need to do anything in the flow other than assign the catalog task. However, there are some details that Runjay has not included to make this solution specific to your situation.
1. You will need to make sure the variables are mapped to the location field in the catalog task (right now, the field is blank because you are not populating it with the selected value from the form).
2. You will need to be very specific with setting up the condition, as the assignment rule has the ability to override other processes, and you may end up impacting catalog tasks created for other teams and run into an issue with misdirects.
