Using fix script same table we need to copy from one field to other field
mani55
Using fix script same table we need to copy from one field to other field i tried with below code but it's not working let me know my mistake
var ga=new GlideRecord('sn_compliance_policy_exception');
ga.addEncodedQuery('policy=87420b0bc3ef71103cbbfb1f0501317b^cmdb_ciISEMPTY');
ga.query();
while(ga.next()){
	ga.cmdb_ci=ga.user_input;
	//current.name = current.u_imei_string;
	ga.update();
Hi, you didn't change anything in the script I gave you right ?
For me it works fine, the record comes up in the cmdb_ci field correctly. Also one thing, you are sure right that the input provided in the user_input field is the name of the cmdb_ci item ? if the name doesn't match then the cmdb_ci wont get populated.
16 REPLIES 16
Hi @mani55 - Where is user_input coming from? I would have serious reservations about matching on text input since CI names aren't necessarily unique, but technically something like this should work:
// Instantiate GlideRecord
var ci = new GlideRecord("cmdb_ci");
// Get the name of the display field
var ciDisplayName = ci.getDisplayName();
var policyException = new GlideRecord('sn_compliance_policy_exception');
policyException.addEncodedQuery('policy=87420b0bc3ef71103cbbfb1f0501317b^cmdb_ciISEMPTY');
policyException.query();
while (policyException.next()) {
    // Query cmdb_ci for a match
    if (ci.get(ciDisplayName, policyException.getValue('user_input'))) {
        // If there's a match, set cmdb_ci
        policyException.cmdb_ci = ci.getUniqueValue();
        policyException.update();
i tried with below script but it's not working
var ci = new GlideRecord("cmdb_ci_pc_hardware");
@mani55 Could you please clarify which field you want to populate from which. User input value from cmdb_ci or vice versa.
we have this two fields like cmdb_ci field and user input we have in sn_compliance_policy_exception table . already  we have value in user_input table and it's string field . cmdb_ci is refrence field and it's refereing cmdb_ci_pc_hardware table what we need is we need copy from user_input to cmdb_ci field in sn_compliance_policy_exception table
Hi @mani55 ,
Please try the below script, it's working for me:
(Change the field names accordingly if required)
ga.query();
if (ga.next()){
    var gN = new GlideRecord('cmdb_ci_pc_hardware');
    gN.addQuery('name', ga.user_input);
    gN.query();
    if (gN.next()) {
        ga.cmdb_ci = gN.sys_id;
        ga.update();
If my response proves useful, please indicate its helpfulness by selecting " Accept as Solution" and " Helpful." This action benefits both the community and me.
