Using fix script same table we need to copy from one field to other field
mani55
Using fix script same table we need to copy from one field to other field i tried with below code but it's not working let me know my mistake
var ga=new GlideRecord('sn_compliance_policy_exception');
ga.addEncodedQuery('policy=87420b0bc3ef71103cbbfb1f0501317b^cmdb_ciISEMPTY');
ga.query();
while(ga.next()){
	ga.cmdb_ci=ga.user_input;
	//current.name = current.u_imei_string;
	ga.update();
Hi, you didn't change anything in the script I gave you right ?
For me it works fine, the record comes up in the cmdb_ci field correctly. Also one thing, you are sure right that the input provided in the user_input field is the name of the cmdb_ci item ? if the name doesn't match then the cmdb_ci wont get populated.
16 REPLIES 16
Hi i Used below script in fix script after that i am checking in list view cmdb_ci value is not displaying but when i open any single record i checked that record XML cmdb_ci value showing
our script related XML:
manual update record
