Using Flow Designer, how do I end a flow?
tomitle
I am see that I need to add an End Flow Logic option .... This will stop the execution of the flow.  But I do not see a way to do this. (see photo/attachment)
Paige Duffey
Hi. Click the Plus, then Flow Logic, then you should see logic to End the flow.
Paige Duffey
Thank you!  That worked!  Now onward and upward. 🙂
Thanks again,
Tom
It looks like disable
Any Idea About it?
