Using Reference Qual and Variable attributes in an MRV from Catalog item variables
Peter Williams
Good day,
i have two catalog item variables called office and department. These are reference items going to the cmn_location and cmn_department tables
I have an MRV that is linking to a custom table call GL codes. The columns for office and department is also link to the cmn_location and cmn_department tables.
the variables on the gl table is called u_office and u_department
When the user select their office and department i want the GL codes to be filter base on those option
i have this so far got the GL code reference in the MRV
Reference Qual:
javascript: 'u_office='+current.variables.office'^u_department='+current.variables.department
variable attribute:
ref_qual_elements=office^department
the GL codes are coming back with everything listed in it
@Peter Williams ,
make ref_qual_elements=office;department
same deal no records found
@Peter Williams ,
You can remove the entire ref_qual_elements and try again.
If it still does not work , then reverify the backend names of variables you are using in advanced reference qualifier because there might be a typo in there
I recreated the scenario and it worked in my PDI with the advanced reference qualifier
