Using reference qualifier to filter users based on the current user's location
JordyZ
Hi, I have a variable on a catalogue item that references the sys_user table. I'd like that variable to only show the users that are in the same location as the current user's location (i.e current user is European so he will only see European users). How do I do this with reference qualifier?
I've found a post that resembles this problem, but not entirely. I'm new to ServiceNow, so I don't know yet how to tweak the answer to fit my specific case.
https://www.servicenow.com/community/it-service-management-forum/reference-qualifier-to-filter-locat...
Rebecca3
There is a much easier way to do this, without requiring a script include.
gs.getUser().getLocation() returns the location of the logged in user. In the reference qualifier of your variable, you can use it as follows -
 javascript:gs.getUser().getLocation()
14 REPLIES 14
Hi @Kalyani Jangam1 @Mitsua
I am still getting an error even after including the two first lines. What am I doing wrong? Thank you for your patience guys.
Hi @JordyZ
Create new SI and make client callable false and refer below
Try this one for new SI and let me know if it is working or not.
Hey @JordyZ
In your code last line was missing. (type: 'populate_users')
I am attaching here xml of script include.
Please check once by importing it.
Thanks!
Hello @JordyZ
Please refer attached screenshot for reference. You script include look like :
Reference qualifier :
Please mark my response as Correct / Helpful based on Impact.
Thanks!
Hi @JordyZ
Please refer below scrrenshot
Please check and mark answer correct if it will help you.
