Values in list Collector is not visible to users except system admin.
srikanth241
Mega Expert
Hi Team,
I have created a custom table in which i have stored choices list for list collector.
My issue is that choice list is only visible to admin, not for other users , If they try to access that catalog Item , That list collector is empty.
I have not written any acl's on custom table.
so what would be the reason.
any Idea please suggest me.
find_real_file.pngDeveloper CommunityDiscussDevelopCommunity CornerExperts CornerConnect
Hi Abhay,
This link might help you to mark a discussion as answered/correct. Once you are able to do that then please mark the answer as correct. Thanks in advance.
How to mark a discussion as answered in SNOW community?
Hi Abhay,
During the creation of custom table I believe it also created the custom role and mapped to ACL's hence suggest you to Go to System security-->Access Controls and search the Access controls for your custom table and open each ACL and remove the custom role from the ROLE list.
This will resolve your issue
Hit like, Helpful or Correct depending on the impact of the response
Prashant
Hi Abhay,
Since you are not able to view the button for marking the answer as correct, could you endorse the content using the endorse option. This will help in high visibility of the content. Thanks in advance.
