Variable Currency Widget on Record Producer is way too small
Tobi_01
 Hello All,
Im Having a issue with using a Item on a Record Producer.
I am using Type „Custom with Label“ for a variable that should Display the variable currency Widget.
It is displaying it, but just way too small, it is Stored inside a 2 Column container, but just using around 10% of the available Space.
can someone help me with that?
Sandeep Rajput
@Tobi_01 I faced the similar issue in the past, Since OOTB Variable Currency widget is read only. You need to make a clone of it and use that clone as a Custom with Label variable on your Record Producer.
Also, on your cloned widget, you need to add following CSS in the CSS field.
input.currency{
  text-align: right;
  width:auto;
Hope this helps.
@Tobi_01 To make the field read only you need to use ng-disabled="true" in the input put attibutes
<input type="text" ng-model="page.fieldValue" ng-model-options="{getterSetter: true}" class="form-control currency" id="sp_formfield_{{::page.field.name}}" aria-required="{{page.field.isMandatory()}}" ng-attr-aria-invalid="{{page.field.isInvalid || error || undefined}}" ng-blur="formatCompensation()" ng-disabled="true"/>
Please mark my answers helpful and correct as they have already addressed the issue you initially reported.
@Sandeep Rajput  thanks again, it is working. So the Widget is read only now, but i Need it to be only read only based on some conditions. Setting the Read only value in an OnChange Client Script did Not work
You need to control this via the widget's client script.
@Sandeep Rajput Thank you very much for Your Support, i really appreciate it!
but how to make currency dropdown editable ? is that possible to show currencies dropdown so that user can select?
