Variable reference qualifier is not working in Variable editor
vamsi
Variable (Type: Lookup Selectbox ) Lookup Value from table having Reference Qualifier is not working on Variable editor.
i'm working on a requirement on Record Producer, The Requirement is as follows
User will fill some minimal data while submitting the record producer, once the record producer is submitted a custom table record will be created
The record created will have variables (which are hidden during form submission) those variables contains drop down values (Look up Select Box) populated from some tables.
Suppose just as an example consider the table below
TABLE: COUNTRIES& CITIES
CountryCity
USAWashington DC
USADALLAS
USAChicago
INDIAMUMBAI
INDIAHYDERABAD
INDIAPUNE
AUSTRALIASYDNEY
CANADATORONTO
CANADAOTTAWA
Variable1:
Lookup From Table: COUNTRIES &CITIES
Lookup value Field: Country
Unique Values Only: True
Variable2:
Lookup value Field: City
Reference Qual: javascript:'u_country='current.variables.country_1
So the above configuration in Variable2 is populate the values based on country_1 variable on record producer
i.e. if country_1 field contains USA as selected value then city_1 field will only populate Washington DC, DALLAS, Chicago in drop down list.
This functionality is working good on Record Producer but the similar functionality is needed on Form's variable editor where if country_1 value is changed corresponding city_1 values should get populated. This is not working in Variable editor.
Any help is really appreciated.
Vamsi
vamsi
I got the reason behind it
the reason is as follows:
Reference qualifiers in look up select box will not work on OnChange. We have to write OnChange catalog client script on Application variable and you can dynamically populate the options for Operation variable by querying the look up table.
Vamsi
kartik8
Hi Vamsi,
I am facing similar problem. There is a look up field on my record producer which is working fine in record producer form. But after submitting the record producer this variable is hidden in variable editor(once record producer submitted it creates change,the variable editor is on change form). Did you face anything like this? Please let me know if you know the reason behind it. I want this variable to be visible on variable editor too.
Kartik
vamsi
Hi Kartik,
I haven't underwent such scenario but usually all variables will get displayed on Variable Editor unless if you have any Client side Script (Client Script or UI policy or UI Script) explicitly doing some operation. This is just my anticipation/ assumption but there might be any other reasons as well .
Vamsi
