Virtual Agent flow is not working in Prod after being moved from dev instance using update set.
09-30-2024 02:32 AM
Hello everyone,
The Virtual Agent flow is not working in the production instance after being moved from the developer instance using an update set. Could you please review the image below to help address this issue? In the dev instance, the question "What is the best way to follow up with you?" presents static choices, such as email, phone, etc. When I select email or another option, it correctly displays a text box to enter the email or phone number. However, in production, it doesn't proceed to the next step to prompt for the email or phone number. It gets stuck at this point, loading continuously, and the only option is to end the conversation. Can anyone help me to resolve this issue.
Praveen Rajan.
Respected ServiceNow experts,
If you have any insights, please share them with me to help resolve this production issue.
@shane_faber
@Community Alums
09-30-2024 04:25 AM
If possible, can you please share the VA flow snippets. Also, do see the variables section to see if the variable value is being passed properly or not to the next node of the flow. I assume that you will have a decision node post taking the choice for follow-up so check the branch conditions once.
09-30-2024 04:37 AM
Sure Here it is.
I checked all the variables are correct and passing correctly to next node.
06-10-2026 08:18 AM
Hi, have you found solution for this issue? I have the same issue, chat is freezed on Prod and on Test same thing works normally
