What role is required to view flow execution details?
thomaskennedy
When I open my flow and choose More Options | Executions it shows me a list of executions for my flow. But when I click on any row I get
There was an error loading the execution details for this flow context
and a popup saying
Exception while executing request: User doesn't have permission to view the report
So I assigned myself all the roles having flow or fd in the name, like so:
flow_report_viewer
flow_designer_scripting
flow_operator
etc
However this made no difference. What do I need to view the execution for my flow?
The property com.snc.process_flow.reporting.level is set to FLOW.
11 REPLIES 11
Alex111
@Donald B Harden, did you ever get a response from support?  We ran into this same issue and our encryption context we are getting from system is from our security incident analyst role, which isn't going to fly to give anyone that role, plus can't find a good way to remove the roles from the admin so it might not get those context's.
Please update us on the response from support and if you have any documented solutions for it.
Thanks!!
Alex
Nghi1
you'd need to have flow_designer to be able to read the details.
The table is sys_flow_log
