Check if a requested item is part of an order guide in Flow Designer
ray evans
Hi
I need to check if a requested item is part of an order guide in Flow Designer, so i can set a different assignment group depending on true or false. Can anyone tell me which parameters I should be setting from the data pill for the condition?
Ray
Should be something like:
Jon23
Hi ray,
If I understand correctly, I think you want to check the 'Order Guide' field pill on the RITM.
Hi Jon
Thanks for your response - I currently have this set as :
"Trigger - Service Catalog - Requested Item" is " "Trigger - Service Catalog - Requested Item - Order Guide"
Does this sound correct?
Ray
ray evans
Thanks for this
Ray
