How to edit "contact us for help " on esc portal
Prasanna_Patil
Hello All
Can someone suggest how to edit this widget on esc portal
Please hit like and Mark Helpful if you liked it
Prasanna
9 REPLIES 9
@Prasanna_Patil
did you check how that widget renders that contact us?
I couldn't find that widget as well in my PDI
Hi @Ankur Bawiskar i found thisnin my PDI however on client instance its "Get support" widget
Prasanna
Huynh Loc
Hi @Prasanna_Patil ,
Please go to the sn_ex_sp_static_content table (Employee Center → Get Support module) and edit the “Contact us” record.image.png
If this response was helpful, please consider marking it as Correct and Helpful. You may mark more than one reply as an accepted solution.
Tanushree Maiti
Giga Patron
Hi @Prasanna_Patil
If your are looking for OOB HR contact form  then you can look into
page
Please mark this response as Helpful & Accept it as solution if it assisted you with your question.
Tanushree Maiti
Linkedin:
papainest
Hey,
If you want to update contact us information under Get Support in ESC Portal you should use - Get Support in left navigation -> Open Contact Us static content and update as per your requirement. Please see my screenshots.
Mark it correct answer if its helps.
Papai
