How to make another variable dependent on first variable record Producer
Prathamesh Cha1
Hi Team,
I am two variables, Products and Capabilities
Here My requirement is only those capabilities should be visible who has parent=product that you have chosen in above variable.
Here is the example I have chosen product as "3AS_3DS Server"
then only those capabilities should be visible which has parent="3AS_3DS Server"
15 REPLIES 15
Kirthika D
Hi @Prathamesh Cha1 ,
  1. Please specify the types of each variable. From the screenshot, products field look like a list collector.
  2. If the above assumption is correct, try this reference qualifier.
parentINjavascript:current.variables.product.split(',').map(function(id) { return "'" + id + "'"; }).join(',');
Hi @Kirthika D ,
I used "
parentINjavascript:current.variables.u_products.split(',').map(function(id) { return "'" + id + "'"; }).join(',');
but still showing no match found
Both the fields are list collector,
Hey,
Replace : with :
Also, make sure the backend name for product variable name is correct as per your record producer variable & the parent field backend name is correct as per the capabilities table, in the scripted reference qualifier.
Hi @Kirthika D ,
parent backend name,
product backend name
both are correct still giving me error, also I want to fir this query in the same means capabilities should not have record whose life of stage is not end of life
parentINjavascript:(use colon symbol)current.variables.product.split(',').map(function(id) { return "'" + id + "'"; }).join(',') + '^life_cycle_stage!=End of life;
Make sure "End of Life" is the backend value of the choice if Life Cycle stage is a choice variable.
