Bring record producer variables into flow designer
Vaishali 11
I have a requirement where on a record producer there are 2 select box fields and when user makes selection on them and submits the form it creates a case. As soon as the case is created the flow designer is triggered where I want to fetch the value of those 2 fields and send them for approval.
I am unable to fetch those 2 fields data into the flow designer. How can this be done?
Thanks in advance!!
@Vaishali 11 ,
Variable type must be reference and reference should be taken from sys_user table. then only you can able to select it.
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
9 REPLIES 9
@Vaishali 11 ,
Thanks and Regards,
Sarthak
@Vaishali 11
please share your flow steps screenshots.
Sarthak Kashyap
Hi @Vaishali 11 ,
Please check the steps below
Trigger condition is Application > Service Catalog
In Action you have to use Get Catalog Variable
Thanks and Regards,
Sarthak
Brad Bowman
Mega Patron
You can use a Get Catalog Variables activity.  In my Incident Record Producer I have a flow that is triggered when a record is created.  In this activity I use the trigger record data pill in the Submitted Request field, then my Record Producer Name in the Template Catalog Item field, then I can select the RP variables that I want.
This will give you a data pill for each variable.  In scripted actions you may also be able to reference variable values without this 'Get' activity by using something like:
return fd_data.trigger.current.variables.var_name
Ankur Bawiskar
@Vaishali 11
it should work fine with Get Catalog Variables flow action
