Copy work notes from interaction to associated HR Case
tworzala
When creating a new HR case on an interaction, I'm trying to get the work notes from the interaction to copy over to the new HR Case that's associated. I'm trying to create a business rule but not having luck. Can anyone help?
17 REPLIES 17
Here's the exact script I used and its still not working:
// Add your code here
gs.info("HR Case BR Called");
var notes = "";
// Pull work notes from the HR Case
var jn = new GlideRecord('sys_journal_field');
jn.addQuery('name', 'sn_hr_core_case'); // HR Case table name
jn.addQuery('element', 'work_notes');
jn.addQuery('element_id', current.sys_id);
jn.orderBy('sys_created_on');
jn.query();
while (jn.next()) {
notes += jn.value + "\n\n";
// Update related Interaction record(s)
var it = new GlideRecord('interaction');
it.addQuery('hr_case', current.sys_id); // field linking interaction to HR Case
it.query();
while (it.next()) {
it.work_notes = notes;
it.update();
gs.info(":Notes = " + notes);
})(current, previous);
Hi @tworzala ,
Please check that you are querying to correct record, try to add logs in while of jn glide record,
gs.info(":Notes = " + notes); are you getting the value in this log or not ?
var notes = "";
jn.query();
while (jn.next()) {
gs.info("Inside While =  " + jn.value);
it.query();
while (it.next()) {
gs.info("Inside Whilw 22 ");
it.update();
Check logs that I added in the script
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
I see all the info logs except inside whilw22 and none of the work notes are visible on the HR case.
Hi @tworzala ,
On interaction table do you have the field called hr_case? if yes then check current.sys_id contains hr_case's sysId, only in this case it will go inside while.
Thanks and Regards,
Sarthak
Ok, no we don't have the hr_case field on the interaction table. Makes sense then.
The rule still isn't working to copy though. ANy other ideas?
