IAR for HR not working
ge3
Issue Auto-Resolution (IAR) for sn_hr_core_case records continuously unassigns bot from target record due to AI Search not finding results.
After setting up IAR for HR on sn_hr_core_case on GI as HR service, upon submission of case from portal, the HR bot is assigned to the case for a second and unassigns immediately, What else needs to be configured?
1. Can you make this system property true "com.glide.cs.notification_newuser_webclient "
2. Can you change requester from Opened for to Subject person
Are you trying in PDI? IAR won't work in PDI's
Can you assign both admin and sn_hr_core.admin role to HR BOT user
Make sure short description is removed from predicted fields
While submitting general inquiry request please enter "request for leave", or "download a policy document" keywords
No i am on my client instance plus org instance which i newly installed IAR but HRSD is already installed. Still no success in adding roles to hr bot.
Here's my current config:
ge3
No valid user for AI Search,Intent prediction service is not enabled for this task - this is another error i am getting.
I think I got it to work. Wondering why Opened for is not working? I did a few customization to get this to work including the predicted fields.
Now i am getting recommendation links with incorrect URL (hrportal_default when it should just be hrportal) for KBs and catalogue pages that won't open. Where do I change the links of the recommended articles/catalogues?
Also, in the conversation passed onto the case, the links are not accessible (security constraints) - see screenshot below.
