IAR for HR not working
ge3
Issue Auto-Resolution (IAR) for sn_hr_core_case records continuously unassigns bot from target record due to AI Search not finding results.
After setting up IAR for HR on sn_hr_core_case on GI as HR service, upon submission of case from portal, the HR bot is assigned to the case for a second and unassigns immediately, What else needs to be configured?
1. Can you make this system property true "com.glide.cs.notification_newuser_webclient "
2. Can you change requester from Opened for to Subject person
ge3
I got the KB link to work now (changed the search results portal value) but when catalogues are recommended, it seems to redirecting to a service workspace view which is broken like below. it always has that SWP in the URL, where can i remove that?
https://xx.service-now.com/swp?sys_id=6e595f95878cb090ea40a75d3fbb359f&id=iar_sc_cat_item&referrer=v...
