Issue using Flow Designer to load and transform data from a Data Source
Javeria
I have a data source with 3 transform maps attached to it and a scheduled job triggered from flow. The flow first fetches data from a third party and uploads the attachment to the data source. Once that’s done, the scheduled job is run from the flow via a script action.
The issue is that the REST call runs multiple times in the same flow (using a do-while loop). Before uploading the next file, we need to delete the previous attachment; otherwise, the load step fails with an error saying no/more than 1 file attached. I tried adding a postscript on the scheduled job to delete attachments, but that isn’t working.
Is there a way to always pick the most recent file from the data source for load & transform?
As an alternative, I tried using GlideImportSetLoader and GlideImportSetTransformerWorker, but that throws errors in the scoped app (HR Integrations). We also want to avoid putting this code in a global script include and then calling it from the HR scope.
Any guidance or best practices would be appreciated.
@Ankur Bawiskar
Ankur Bawiskar
@Javeria
I will suggest before adding file to Data source, always delete the existing one and then attach new one.
with this you will always have latest file on data source.
I did that, maybe some raise condition is happening file is deleting before loading. What if I go with  schedule job logic in flow and have wait condition on state field to wait flow unless state is processed?
@Ankur Bawiskar
That's the question: how to know if load/transform is completed then only I can delete file. In the flow in wait for condition I am unable to access sys_import table to check state if it's processed.
Also below is my script include code:
    loadData: function(dataSourceID) {
        var dsGR = new GlideRecord('sys_data_source');
        if (!dsGR.get(dataSourceID)) {
            gs.error("Invalid Data Source sys_id: " + dataSourceID);
            return null;
        var loader = new GlideImportSetLoader();
        var importSetRec = loader.getImportSetGr(dsGR);
        loader.loadImportSetTable(importSetRec, dsGR);
        importSetRec.state = "loaded";
        importSetRec.update();
        var importSetId = importSetRec.getUniqueValue();
        return importSetId;
    transformData: function(importSetID) {
        var transformWorker = new GlideImportSetTransformerWorker(
            importSetID,
            'transform map sys_id'
        transformWorker.setBackground(false);
        transformWorker.start();
        return ImportSetID
@Javeria
you said 1st flow pulls and adds file to data source.
in that flow itself you can delete the file.
But I believe you are saying by the time the same flow runs again you are not sure if earlier import has been completed or not?
