Reference Qualifier to filter Users with HR Profiles
Joanna7
How should look like reference qualifier for User table reference field [sys_user] to filter only users with HR Profiles [sn_hr_core_profile]? This is for record producer in standard Service Portal, not in ESC (ESC does not exist).
9 REPLIES 9
@Ankur Bawiskar I am now trying to do the same on the SP but cannot seem to get it working. I just did the same as for the backend field. Please see what i have done below
@vahmed
Can you raise a new question for your question as this is quite older thread.
tag me in that question
No problem at all. Will do thanks.
John Zhang1
You can configure like following a sample
Mark ✅ Correct if this solves your issue and also mark ???? Helpful if you find my response worthy based on the impact.
Thanks for your help.
