Script returns undefined for reference value
preethigovi
Hi Team,
I was learning on scripting where i had uses case to fetch manager (reference to user table) in HR profile and populate on filed on other scoped table
var hrProfileGR = new GlideRecord('sn_hr_core_profile');
hrProfileGR.addQuery('sys_id=04556f50471f1110e72d7116536d43f9');
hrProfileGR.query();
var managerValue = hrProfileGR.getValue('manager');
var userValue = hrProfileGR.getDisplayValue('user')
gs.info('PreeManager value: ' + managerValue);
gs.info('PreeManager2 value: ' + userValue);
Can you point out why its returning null value for managers?
@preethigovi
use this script
while (hrProfileGR.next()) {
    var userValue = hrProfileGR.getValue("user");
    var userProfile = new GlideRecord('sys_user');
    if (userProfile.get(userValue)) {
        hrProfileGR.u_manager = userProfile.manager;
        hrProfileGR.update();
14 REPLIES 14
@Bhavya11 Its reference to user table.
Hi @preethigovi ,
your script your fetching display value then setting that with the reference field so its not work.
hrProfileGR.addQuery('number=HRP3083319^u_managerISEMPTY');
gs.info('PT1');
if (hrProfileGR.next()) {
gs.info('PT Success');
var userGR = new GlideRecord('sys_user');
if (userGR.get(hrProfileGR.user)) {
var hiringManager = userGR.manager;
hrProfileGR.setValue('u_manager', hiringManager);
hrProfileGR.update(); // Save changes
gs.info('Hiring Manager set to: ' + hiringManager);
gs.info('User record not found.');
BK
LinkedIn: https://www.linkedin.com/in/bhavyashree-karanth-55032a121
YouTube: https://www.youtube.com/@NowWithBhavya
preethigovi
@Ankur Bawiskar @Bhavya11
In show xml it shows value but in field its empty.
@preethigovi
use this script
@preethigovi
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
