Fields and Columns
matthollida
I am attempting to incorporate a new column into a ServiceNow list view, referencing it to the "Grade" field within the form of an asset which is working as expected as provides me the grade of the assigned to user.
Despite adding this field to the asset form, the column consistently displays as empty instead of reflecting the actual grade value associated with the user.
See Images for Reference
How do you make the grade column dependant on user field?
Hi @matthollida
Where you created the field grade, on which table and where you want to show?
The field on the form table was already on the form. I just want to be able to add this as a column in the list view so Grades can be filtered
Hi @matthollida
I create Grade in my user table and the user who has value is showing
Doesn't show for me.
