‎08-28-2025 06:52 AM
Hi Community,
I have a scenario where certain business managers (non-ITIL users) need the ability to view incidents in ServiceNow without being granted the ITIL role. These users:
- Do not need to create, update, or assign incidents.
- Only require read-only access to specific types of incidents (based on conditions such as assignment group, category, or other filters).
- Should be able to view the form details and work notes but not perform any actions.
I’d like to achieve this without modifying the standard incident ACLs tied to ITIL.
I also noticed that:
- I don’t see any SNC-internal role available.
- The sn_read_only role is also not helpful in this case.
Questions:
- What is the recommended way to grant incident read-only access to a custom role (non-ITIL)?
- Should I clone the incident ACLs and adjust conditions for the new role?
- Is there a better approach (e.g., data policies, UI view restrictions, or reporting-only access) for such use cases?
Appreciate any guidance or best practices from those who’ve implemented a similar requirement.
‎08-28-2025 07:18 AM
‎07-28-2026 04:51 AM
I know this thread is a bit older but the snc_read_only role restricts a user to read-only access on tables they are already authorized to access through their other roles and applicable ACLs.
For example, a user with both the itil and snc_read_only roles can read incidents available through their ITIL access, but cannot create, update, or delete incident records.
The snc_read_only role does not grant read access to any table by itself. It must be combined with other roles that provide the required table and record access.
‎08-28-2025 07:20 AM
Hi @Kumar54 ,
You can create custom role with READ ACL on incident table to restrict the access and add role to users.
Also you can utilize the ITSM role sn_incident_read.
If my response helped please mark it correct and helpful.
Kind Regards,
Sankalp
‎08-28-2025 07:22 AM
I can't create a custom role for this requirement. These users primarily need the ability to view incidents and, in some cases, possibly update the state. They are not directly involved in incident handling or resolution, but act as store managers who oversee incidents created for their location.
