Need help to Trigger notification when Incident SLA reaches at 80%
prakharmahe
1-> In this workflow, I didn't understand that how this is getting data of SLA from incidents, I checked for the property in sys_properties table but didn't find any property names like this.
2-> If I want to create a new workflow in which at 80% an email notification will trigger then how to create one?
2 ACCEPTED SOLUTIONS
Dr Atul - LNG
Hi
The easiest approach would be to copy the existing flow and simply change the threshold from 50% to 80%. and use  flow instead f workflow
https://www.servicenow.com/docs/r/it-service-management/service-level-management/flows-for-sla.html
Tanushree Maiti
Hi @prakharmahe
Try this:
Step 1: Create the Event Registry
  • Navigate to System Policy > Events > Registry> New.
  • Fill in the following fields:
    • Event Name: workflow.eighty_percent (or a similar specific name).
    • Table: Select the table your workflow runs on
  • Click Submit.
Step 2: Create the Email Notification
  • Navigate to System Notification > Email > Notifications>Click New.
  • In the When to send tab:
    • Set Send when to Event is fired.
    • Select the Event name you created in Step 1.
  • In the Who will receive tab, select the recipients (e.g., Assigned to, Assignment group, or specific users).
  • In the What it will contain tab, draft your Subject and Message content.
  • Click Submit.
Step 3: Add the Event to your Workflow
  • Open your Workflow in the Workflow Editor.
  • Find the Create Event core activity in the right-hand palette (under the Core tab).
  • Drag and drop the Create Event activity into the workflow at the point that represents the 80% completion mark.
  • Configure the activity fields:
    • Event name: Select the event you registered in Step 1
    • Parm1: Leave as is or pass a specific target user/sys_id if necessary.
Tanushree Maiti
Dr Atul - LNG
Hi
I know flows replaced workflows, but can you help me to understand what 'run during the upgrade' property means and how this workflow is getting details of SLA.
Hi @prakharmahe
I don’t have the workflow anymore, but here are a few details.
As per my understanding:
This is a way to provide the ability to flag workflow timers as upgrade safe with either:
a) the global property 'glide.workflow.timer.upgrade_safe' property, defaulted to 'false'. When set to true, all workflow timers will continue to run during the upgrade.
b) a new "Run during upgrade" activity variable on the Timer activity with three options: Always, Never, and "If global property is true (glide.workflow.timer.upgrade_safe)".
The default is property value.  If an author has explicitly chosen either "Always" or "Never", it should be honored over the global property. if the value is property/None, the property controls the Timer's behavior
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0680592
Tanushree Maiti
Hi @prakharmahe
Try this:
  • Click Submit.
  • Click Submit.
Tanushree Maiti
