Return False is not working in onsubmit client script
akhila13
In the below script return false is not working.Can anyone help me
function onSubmit() {
var ga = new GlideAjax('IncidentAssignmentGroup');
ga.addParam('sysparm_name', 'canResolveIncident');
ga.addParam('sysparm_state', g_form.getValue('state'));
ga.addParam('sysparm_group', g_form.getValue('assignment_group'))
ga.getXML(setState);
function setState(response) {
g_form.addInfoMessage(answer);
// g_form.addErrorMessage("test");
//retrun false;
if (answer == 'Cannot Resolve') {
g_form.addErrorMessage("Cannot change the state to resolved");
return false;
I got the issue  the function should close after if, try below:
if (g_scratchpad.isFormValid) {
return true;
var actionName = g_form.getActionName();
//retrun false;
if (answer != 'Cannot Resolve') {
g_scratchpad.isFormValid = true;
g_form.submit(actionName);
return false;
9 REPLIES 9
Hi Raghav,
I modified the code. Still not working 😞
return true;
return false;
else {
can you alert(answer); and check if you are getting correct value?
Also try:
g_form.submit();
else {
return false;
The error message is coming correctly . But the form is getting saved
return true;
//retrun false;
return false;
it works.. Thanks a lot Raghav...
