Variable Editor changes not saving in Test instance
10-09-2025 05:02 AM - edited 10-09-2025 05:04 AM
In our Dev instance, changes made in the Variable Editor are saved correctly when the incident is updated. However, in the Test instance, the same functionality is not working — updates in the Variable Editor are not being saved.
10-09-2025 06:01 AM
Hi @Community Alums
Please try updating it again in the Dev environment and make sure it’s captured in the update set. Then, move it to Test once more, mate.
10-09-2025 06:11 AM
Hi @Dr Atul - LNG I just captured the form layout in update set and moved to UAT
you mean same thing should I repeat?
10-09-2025 06:28 AM
Yes, just change some values so that it get capture it again.
10-10-2025 04:02 AM
Thank you @Dr Atul - LNG and @Ankur Bawiskar
I found the solution
There were two incident variable editors on the form under 2 different sections
So I removed one from form designer.
10-12-2025 08:37 PM
@Community Alums
Glad to know.
Please mark your own response as correct and close the thread.
