form context menu view not displayed
amran ahmed
I am currently building a custom application and when I went to create two different views for my form view, I came across an issue. In my dropdown within my form view, the context menu doesn't include the view option -- it is automatically set to the default view and I can't seem to change between views. I granted permissions using the view management module however my other custom applications, the form context menu includes the view option from the dropdown.
Since the context menu is OOB, I am wondering how to access the view option and some of the other OOB options within my form context menu.
I'm not sure I follow.
Can you detail the steps for me.
Just for future reference for myself, why do the rest of my custom applications have those OOB options and this particular doesn't?
Do you mean if a view rule is set on that table, then the view won't showing in the menu? How to show the view option even a view rule is created? Thanks
