I am not able to select value for reference field. It's not showing the options list
SanSri1122
I am not able to select value for reference field. It's not showing the options list please give suggestions to solve this issue.
SanSri1122
yes its having reference qualifier and removed it so now its working.
Arun151
Even I'm facing the same issue did u get any solution. If so can you please share as it will be helpful for me.
SanSri1122
