Instance is unusable, general loading takes a long time.
Options
08-16-2022 11:09 AM
Instance load times are extremely high. Reference fields load incredibly slow, etc.
Can someone assist please.
Options
08-17-2022 10:56 AM
Hi Allen,
If that doesn't resolved your issue then unfortunatly there is no resolution for that as of now. Its a Known issue these days. Instance help is no longer monitored by servicenow anymore.
Best you can do now is to release the instance and request for new one if you dont have important data.
Mark Correct or Helpful if it helps.
***Mark Correct or Helpful if it helps.***
