AMBClient exception when instantiating a AMBClient. Connection is not successful
Jourdan Rothsc1
Installed a new MID Server to do a Network Discovery. Received the following error after setup was completed.
What would cause this issue and more importantly what is the best direction to resolve getting this error message.
FYI: Discovery was successful for SNMP Behavior of the network device.
Jourdan
Update: IS there a way to find the port used fo the
Asynchronous Message Bus communication.
Finally figured it out, Appears when you are assigning the name of the proxy server in the MID Server configuration you do not include the http or https:// just the fully qualified name. once that was changed then the communications thru the proxy was established.
