Discovery error : IOException - An existing connection was forcibly closed by the remote host
Options
08-29-2022 10:17 AM
I am trying to run Quick Discovery for an IP and getting the following error in shazzam probe.
<results active="1" alive="1" probe_time="7502" result_code="0" total="1">
<result active="true" alive="true" ip_address="13.107.246.51">
<scanner name="HTTP" port="443" portprobe="http" protocol="tcp" result="io_error" service="https">
<error_msg>Problem while reading HTTP response: : IOException - An existing connection was forcibly closed by the remote host</error_msg>
</scanner>
<scanner name="HTTPS" port="5986" portprobe="winrm_ssl" protocol="tcp" result="timed_out" service="winrm_ssl"/>
<scanner name="HTTP" port="80" portprobe="http" protocol="tcp" result="open" service="http">
<response_code>200</response_code>
<http_version>HTTP/1.1</http_version>
<response_text>OK</response_text>
</scanner>
<scanner name="SLP" port="427" portprobe="slp" protocol="udp" result="timed_out" service="slp"/>
<scanner name="NBT" port="137" portprobe="wins" protocol="udp" result="unresolved" service="ms-nb-ns"/>
<scanner name="DNS" port="53" portprobe="dns" protocol="udp" result="unresolved" service="dns"/>
</result>
Please help what could be the cause of this issue.
Labels:
Discovery
Options
10-21-2023 09:12 PM
Hi Geet,
What type of Device are you trying to discover ? is it Server, Network device or Storage device ?
