11-03-2025 11:11 PM - edited 11-03-2025 11:12 PM
requirement is if 3 alerts is created in servicenow , group them which is working but now what is happening is 3 alerts are created but this rule is not matching and showing some different rule in activites under work notes ,some other rule is taking precendence. ..so now if 4 alerts re created it should not group it
pls can someone help me where i am going wrong..
in the below picture it is creating a new alert instead of making 607 as parent which is expected
11-04-2025 02:35 AM
so first log : gs.info("this is li3ne 13 from me"); this is printed 6 times in log table but it should be 3 becuase setlimit(3) is provided in the script
11-04-2025 03:58 AM - edited 11-04-2025 03:59 AM
this is the log that i have printed it is coming but alerts are not grouping for the rule which matches
CODE which is have written:
@Ankur Bawiskar
@Tejas Adhalrao
can you guy'z help me in debugging thnx in advance.!
11-04-2025 04:21 AM
try to use GlideAggregate
var alertGrCount = new GlideAggregate(table);
alertGrCount.addEncodedQuery("sourceLIKEIRIS^severity=4^state!=Closed^parentISEMPTY");
alertGrCount.groupBy('parent');
alertGrCount.query();
var totalMatchingAlerts = 0;
while (alertGrCount.next()) {
totalMatchingAlerts++;
gs.info("Total matching alerts: " + totalMatchingAlerts);
// Only group if exactly 3 alerts match
if (totalMatchingAlerts === 3) {
var alertGr = new GlideRecord(table);
alertGr.addEncodedQuery("sourceLIKEIRIS^severity=4^state!=Closed^parentISEMPTY");
alertGr.orderByDesc("sys_created_on");
alertGr.setLimit(3);
alertGr.query();
var storeID = [];
while (alertGr.next()) {
storeID.push(alertGr.getUniqueValue());
gs.info("Alerts to group: " + storeID);
var result = {
"parent": storeID
var getStr = JSON.stringify(result);
gs.info("Grouping result: " + getStr);
return getStr;
gs.info("Not grouping alerts since count != 3");
return false;
11-04-2025 09:10 PM
let me try
11-04-2025 09:51 PM
tried but failed, it is not picking 3 as count applied logs
CODE :
11-05-2025 07:28 PM
did you get time to review this ? @Ankur Bawiskar
